can anyone tell me how to make a video file dvd compliant so that i can burn it as a dvd video file using nero. e.g an mpeg or mpeg2 file...thanx
*ahrm*
In NTSC, it must be "a DVD resolution", meaning 29fps and one of the following:
720x480, 704x480, 320x480 (someone wanna remind me what the widescreen-enhanced numbers and the ultra low-res numbers are?)
Also, the audio has to be in a compliant format, meaning either PCM 44khz, or MPEG Layer II... uh... err... I forget the bitrate restrictions here as well.
Most encoding programs have a preset for DVD compliance.
- Gurm -
you need to author your MPEG files into VOB, IFO, and BUP files. to do that you need an authoring program such as TMPGEnc DVD Author.
Dvd compliant files=720(702x480/576)mpeg2
(352x480/576)mpeg2
(352x240/288)mpeg1
Audio=48khz pcm&ac3 and mp2 but mp2 more for pal.I think,therefore i am a hamster. -
Vob files contain the video,audio,and other stream information. Ifo and bup files contain the instructions to tell your DVD player's firmware how to play the files. If you have vob files you can avoid authoring by using IFOEDIT to create the ifo and bup files.
720x480,704x480,352x480,352x240
ac3,PCM,MP2 all at 48K
I think these the "legal" resolutions and audio. IFOEDIT has an authoring option which allows you to use "non-legal" streams,for example I've converted SVCD to DVD with it's 480x480 and 44100 audio and they've played on all the DVD players I've tried them on. -
ive tried tmpgenc dvd author and it works fine for me. thanx for all ur advice guys. ive jus gotten me a new dvd burner and wanna put my vcd backups onto dvdr. i can put several onto 1 disc right? using the reauthor function in dvdshrink?
DVD compliant and 60fps?
By fearmyrage in forum Authoring (DVD)Replies: 11Last Post: 28th Apr 2012, 22:51 -
creating an AVCHD compliant DVD?
By tommy2010 in forum Video ConversionReplies: 5Last Post: 2nd May 2010, 00:30 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
Why is my movie not DVD compliant?
By johnharlin in forum Video ConversionReplies: 19Last Post: 3rd Jan 2008, 21:11
