I've been doing a bit of experiementing with AVI and MPEG capturing with my ATI AIW Pro 32mb card. I've just upgraded my Intel Celeron 500mhz PC from Win ME to Win XP. I've seen a big difference in performance from the card. (A big difference)
If people want the best quality from the ATI card, this is these are the best settings to create SVCD or VCD.
Download AVI_IO and the HuffyUV lossless codec.
This could be from PAL or NTSC
640x480
25 or 29.97 fps (depending PAL or NTSC)
44.1khz audio PCM
YUY2 (in right column of HuufyUV settings)
This gives great quality for encoding to VCD or SVCD.
(No blocks at all)
I think the ATI software sucks for MPEG encoding (only for slower machines like mine). I can get upto 640x480 in I frammes, MPEG2 with any bitrate. This really sucks with quality going back down to VCD or SVCD.
I can't really use my technique for vids longer than 3 mins becasue i'm limited on disk space.
Hope this helps
P.S. You really need 20GB plus spare to use this technique
<font size=-1>[ This Message was edited by: hotmat4 on 2001-11-16 14:37:03 ]</font>
Hotmat4, is it better due to XP or due to AVI_IO/HuffyUV lossless codec ? It looks like you captured in AVI format. I am not quite familiar with AVI_IO/HuffyUV. I have the 733Mhz machine w/ 30G HDD, 256M RAM, but the MPEG1/VCD capture is still very blocky. I can not do any bit rate more than 1150k without frame drop. Thanks
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 18:41 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 06:02 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 09:52 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36
