  1. when i convert vob files to avi using dvdtoavi program why do i get lines on the screen when there are fast moving objects
    surly it shoud play like the vob file does which plays like playing a dvd
    what am i doing wrong
    cheers
  2. When a software program plays a DVD it deinterlaces it, when a DVD player plays to a TV you don't see these lines cause that's how TV's work. DVD2AVI doesn't deinterlace, so your AVI will have these lines. Most people don't use DVD2AVI for anything other than allowing other programs to open the DVD, such as Nandub (using GuardianKnot) or TMPGEnc. If you go to Doom9.org he has a very good guide on using DVD2AVI with several other programs.
    Jan 2001
    Vancouver/Portland
    There's a good chance you can deinterlace in realtime (when you save the movie as an avi).
    Hit F5 in DVD2AVI. It will preview the movie.
    If it shows up FILM 95% or higher, you can enable Forced Film. Which WILL get rid of the Interlaced lines. Otherwise don't enable it, or else your will movie will look messed up.
