Hello, i have a pioneer 5100 dvd recorder, i have successfully transfered my home videos to dvd minus discs, i now wish to use my PC and some software to edit them and include menus, titles, and chapters, and then burn them back onto a new disc all edited and the like, i have a problem though, firstly the PC will not recognise the file type, noe this maybe that the software i am using will not recognise the file type i am not sure, i have tried to convert the files using vobedit but to no avail, so i am asking if the following software (ULead Video Studio 8) will do the trick, ie convert the files so they are recognised and in fact edit the way i wish etc, thanks to all for your help, cause i know you will help, wont you ???
Did you try Ifoedit to rip the mini DVD you have burned?
Its made by the same developers of VOBedit.
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
