I have a panasonic DMRE-50, I bought a 25 tub of Mirror Platinum DVD-Rs to try them out and they worked fine, so I bought another 100, lately I've been having a few problems, Inserting a new disc is fine, it reads it no problem and records onto it fine, however when I try and play the disc again it struggles to read it, either failing completely or reading the disc as empty. Does anyone have any suggestions (other than binning the 100 discs and buying another brand)?
Ya..throw them in the garbage and buy another brandDoes anyone have any suggestions (other than binning the 100 discs and buying another brand)?
Buy some panasonics. If you want cheap, I have used hundreds of Accus -r dvds from meritline.com perfectly in my e30 for $62/100 but the price keeps getting better.
Panasonic DMR-ES35 fails to read discs
By lilblu in forum DVD & Blu-ray RecordersReplies: 8Last Post: 13th Sep 2012, 14:14 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 13:34 -
DVD-R discs work and then fail in Panasonic DMR E85H
By herefordjw in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 12:09 -
Panasonic DMR-EX85: Recording NTSC discs on UK model
By webstar in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Jul 2007, 18:57
