Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
  1. I found some better solutions to audio out-of-sync problems here. My favorite on that page that doesn't require any rendering is the usage of AVI Frame Rate Adjust, towards the bottom of the page. Very easy!
  2. Member Crazyj32's Avatar
    Apr 2006
    Nice Guide but using a wave file? The wave will be bigger than the avi!
    I got a better way, use MP3 Splitter & Joiner PRO to edit the mp3 without transcoding. If you need to insert a 300ms silence just use the splitter to cut out a 300ms clip from the beginning and merge it where you need it.
    It works very well but with one problem: It seems to only merge your mp3's in alphabetical order.
    I used it to fix a 4600ms and a 5000ms vbr MP3 offset in a 2-cd backup I have. It works perfectly now, each avi still fits nicely on a cd.
  3. Member Benjy's Avatar
    Oct 2009
    Canada
    How can I determine the audio delay in an mkv file ???
