  1. My friend ask me to copy a VCD to VCD. it's home made by professional videographer, but it does not allow me to copy. SOme type of lock slow down transfer rate to few bytes...ANy solution?
    Thanks,
    shreeit
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    What are you using to copy?
    Try CloneCD or maybe even Nero.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    If you have a tv capture card you could do a real time capture. I doubt this "copy protection" includes macrovision {unless this is one serious videographer}.
    Kevin
  4. Definately not microvision type of protection. I tried both CloneDVD and Roxio. Did not try Nero. Even copying file from VCD to C drive, I notice, only one file slow down copying process next to zero.
    Shreeit
  5. I notice, only one file slow down copying process next to zero.
    me thinks it's your system. Else this videographer should contact Hollywood RIGHT NOW
    Don't have a fix for you though, sorry. Too many factors....
    Else try CloneCD as mentioned by other poster, not CloneDVD. Or try Blindwrite, Fireburner, etc. good luck.
  6. Greetings Supreme2k's Avatar
    Feb 2003
    Check for scratches or smudges on the disc. VCD should copy almost as easy as photocopying it
  7. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    i use Nero6 to copy copyright protected VCD... do a CD to CD copy or Quick Copy. I never have a problem with any copyright protection...
    hacking the Net using typewriter :D
