Hi I used the following hack but when i did it did not change the player from region 2 to multi region but it went to region 1. Can anyone tell me what i can do. Any help will be helpful.
1)Via the "System" button on your Philips remote, on your recorder (no disk in recorder), change the "Remote control used" from "DVD Recorder" to "DVD Player". Store it. (This is IMPORTANT!)
: 2)On your Philips remote press Play 159
The display on the recorder should now change to eleven dashes.
: 3) Still using your PHILIPS remote, tap in 121 212 005 255 (the last few digits will NOT be visible on screen but they WILL be there). Now press "Play" on your PHILIPS remote.
: 4)Power down your recorder, wait a few seconds and Voila!!. You now have a region-free
Check here for more info:
http://www.home.zonnet.nl/jeroenverhaar/en/indexdvd.htm
And here(all the way at the bottom of the page):
http://www.dvdplusrw.org/Article.asp?mid=0&sid=1&aid=2 -
I've been on them sites hech54 but they don't seem to help me. What code do i put in, this is my firmware below but what verson is it.
DI E2/24254 AN 130290 SV 70
BE 20.3.23 DV NOT PRESENT FP 13
P1_7_B 20031114_1201 DEVALEAD 5.12
BASE_20031110_LFF16A 20031110_0840RP -
I really don't think firmware has anything to do with your problem. If I were you I would try to get it back to it's original region code and leave it there. Philips recorders are TERRIBLE players anyway and in my opinion playing factory pressed DVD's in a Philips Recorder shortens it's life expectancy drastically.Originally Posted by VOYAGERXP
Sorry I couldn't help more....I don't muck with my Philips recorder...I paid too much for it.
philips dvdr 3455h
By mikes94547 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Dec 2008, 09:36 -
Philips DVDR 3475/37
By jtavegia in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2008, 14:33 -
Philips DVDR 3355 issue
By DDP in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jul 2007, 11:31 -
Philips DVDR 610 Problems
By Rachel85 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Jul 2007, 08:36 -
Philips DVDR 3475
By cabralmj in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Jul 2007, 15:46
