When downloading movie files off of suprnova.org, when I download say, an entire season of some tv show, it’s split into 22 different files (one for each episode). When one is finished, though, it won’t let me play it until all of the episodes are downloaded. They’re usually xvids, GSPOT doesn’t even recognize it as a valid .avi file until all of the flies are downloaded. So my question is this: how can I watch the first few episodes, which are complete, while the others are still downloading? I’d appreciate any help.
My advice:
If the episodes are available on DVD, buy them. It's not worth the hassle of downloading (usually) crappy re-encodes.
If that's not the case, there's a program called eDwatch that you can use to preview. The side benefit is that it will create an AVI which you can convert and burn, if you'd like. -
Programs like Bit torrent download the files in pieces. chances are the file is not fully complete as the files are not downloaded in order. And usually the stuff you get is crap. it's much better to just go out and buy the dvd. you'll get better video and sound quality.
The first few episodes are the same size now as when they're all done downloading, but they just won't play. The first season ones were fine rips, i'm not going to spend $50 on DVDs that are only good the first time through.
Steps to repair a partially downloaded .avi that has a missing header.
By torrentcrazy in forum User guidesReplies: 12Last Post: 4th Feb 2015, 19:11 -
Player for watching .flv files
By jbandy1 in forum Video Streaming DownloadingReplies: 5Last Post: 1st Aug 2012, 09:21 -
Sort files by certain video/audio properties
By darknite999 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2011, 14:40 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
Someone to fix partially deleted .MOV files
By Zunder in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2010, 13:17
