  1. I need to join 2 avi/mpegs into1 Help please.
    I've been reading the guides and trying to find the right program for this.
    I think vdub does it but I can't find the guide.
    I have a number of movies in parts that I would like to make into a full dvd, 1 movie.
    Please help me and if posible leave a link to the guides.
    Thank you.
  2. ok for avi in virtual dub, open the 1st file, then click file menu and select apend avi segment, in video menu select direct stream copy, then in file again save as avi simple, if it gives u and error to do with vbr audio, ull need to open each segment in turn, and select, direct stream copy for video, and in audio menu full processing mode and save each segment individually then do the apend avi , for mpeg i usually use mpeg tools in tmpgenc
  3. Wombles MPEG Video Wizard does a wonderful job at that
  4. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    For multiple avi's to be joined I just use the batch encode to 1 file in MainConcept which gives me just 1 mpeg, see sig.
