I experimenting with an ATi AiW 128, which seems to turn in reasonable quality on small frame sizes (352 by 576 for example).
However I can't get it to capture sound and neither can I get the Win98 sound recorder to record either.
I'm using the onboard AC97 sound card on my K7S5A M/B which uses the C-media CMI9738 chipset.
I believe the drivers are reasonably current.
Any ideas Guys?
PN
1. Disable the onboard sound and get a proper sound card.
2. If you still want to use the onboard sound, make sure you have the audio from your source going to the LINE-IN of your onboard sound and also make sure you have the Line-in checked on the sound properties recording window.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
unable to get date code from DV capture
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2009, 16:24 -
Unable to capture hdv with Vegas 8 Platinum
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd May 2008, 06:10 -
Unable to capture stream
By matiz in forum Video Streaming DownloadingReplies: 0Last Post: 28th Apr 2008, 14:38 -
Unable to capture screen shot for background
By Cole in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Jan 2008, 15:53 -
Unable to Capture
By clanpitt in forum Capturing and VCRReplies: 8Last Post: 27th May 2007, 06:17
