Hi,
I've the same problem with BBMpeg and muxing the Videostream with two audiostreams. Can you transfer some replies to me if you get some? I'm not so often in here. My Adress: jhar67@web.de
Thanx
AnonymousGuest
First, make sure you have the latest BBMPeg - some earlier versions were problematic in this area (b18 is the latest - see the Tools link at the left).
If you still get them, supposedly setting the initial pack startup delay (lower left of mux screen) to a larger number helps.
I've also successfully used the old Mpeg Tool from TMPGEnc beta 12 called "VBV_Optimization" - it remultiplexes the mpeg and fixed the underflow problems for me when I was still using problematic version of BBMPEG/ -
where it says mux rate, replace those numbers with 0. BBMpeg expected a different value than what your files were encoded with. Before it starts to mux, BB will look at the streams, usually you'll see an error that tells you "your bit-rate is too high, re-encode with a lower bit-rate", and "watch out for PTS underflow and overflow."
Default SVCD settings for BBmpeg is 2376, so just change the mux rate to 0, and it'll mux for you at your higher bit-rate encoded video.
The Film Machine Problem... MULTIPLEXING FREEZE
By supermannnnn in forum Video ConversionReplies: 3Last Post: 16th Dec 2012, 12:51 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 10:16 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 23rd Apr 2011, 00:59 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 16:52 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 06:45
