I want to run the DVD/VHS AV signal to the TV but also have the PC connected to another output even if it is only VHS out.
So either 2x DVD/VHS out or 1x DVD/VHS and 1x VHS only would be fine.
Does RF OUT supply DVD content ?
If it does this is another option because the TV is only 48cm mono.
I'd obviously go with a separate splitter if need be.
Even if they aren't Aussie models it might still give me a clue where to start looking.
If it is just composite output you want to split RadioShack has a cheap AV composite splitter for $20.00... or you can just use Y cables. (2 at $1.99 each)
Need Help with DVD/Vhs combo...
By shaytala in forum DVD RippingReplies: 12Last Post: 13th Sep 2010, 13:11 -
LG RC195 DVD / VHS combo
By mishon in forum Newbie / General discussionsReplies: 3Last Post: 20th May 2009, 09:06 -
VHS to DVD Combo Machines?
By JXBlack in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Nov 2008, 10:12 -
VHS/DVD Combo Converter
By Evhmoon in forum DVD & Blu-ray RecordersReplies: 12Last Post: 30th Mar 2008, 22:17 -
Best DVD-Recorder/VHS Combo For The $$$???
By expat in forum DVD & Blu-ray RecordersReplies: 4Last Post: 6th Dec 2007, 09:00
