I have an Eye TV USB model. I was wondering which of the following methods would reveal the best quality video. I am recording cable TV signals at the highest settings possible with the EyeTV. I can choose to either save as a MPEG1 or MOV file. When I drop a bunch in Toast 6 it then "encodes" them to burn a DVD. What should I use MOV or MPEG1? What will get me the best quality DVD?
thanks,
k
First, all EyeTV files are MPEG1, regardless of the extension. The .mov files still contain an MPEG1 file, as noted by looking at the 'Get Movie Properties' pane.
For best recording quality, connect to your cable service using a high quality cable no longer than 6-12 feet, and record at high quality.
Reencoding these already compressed files will not yield decent results. It is not possible to capture EyeTV's signal from any other source, since EyeTV actually compresses the signal in Hardware.
Finally, Toast 6 is the best option for recording EyeTV output to DVD or VCD.
If these results are still sub par, there's always EyeTV 200. -
Would recording at HIGH quality [versus standard quality] with an EyeTV USB going to yield THAT much better results when the final medium is a VCD?
A video camera with the quality of an eye
By Northern in forum Newbie / General discussionsReplies: 13Last Post: 17th Oct 2010, 12:40 -
Eye Opener: Cloud Computing Power Requirements
By ahhaa in forum ComputerReplies: 3Last Post: 31st Mar 2010, 07:16 -
Keep an Eye on Video Monkey, VisualHub's replacement.
By terryj in forum MacReplies: 3Last Post: 29th Jul 2009, 23:16 -
Switching TWC-NYC channels with a 'cable eye'
By xmiinc in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2009, 15:02 -
What is the smallest amount of change in color that the eye can detect ?
By Movie-Maker in forum Newbie / General discussionsReplies: 8Last Post: 6th Dec 2008, 10:41
