I have posted this before but I didn't quite get a good answer, so...
I am using version 5.7 of WinAVI and I'm encoding a 700MB AVI file into a DVD. The problem is that the DVD fileset ends up being 2.39MB, even when I select output fileset size to be 4.7GB in the Advanced settings (I leave the other settings on "Auto"). Why is the output fileset not 4.7GB? Does it matter? Will the quality be the same with a 2.39GB or a 4.7GB fileset?
And I do realize I will only get a file of relatively the same quality as the original AVI file. I just want to be able to play my AVI files on my DVD player.
Thanks in advance,
Jason.
The quality should be the same. WINAVI did convert it to the best possible output and it ended up being less than 4.7 GB. hope that helps.
By the way WinAVI is the best tool I have seen to transfer DV into dvd with virtually no quality loss. I have used many other programs but WinAVI does a straight conversion so there is no loss. When video is converted to MPEG and then authored you loss quality but WinAVI takes out the MPEG conversion process out and does a great job of it too.
I am surprised that WinAVI does not get more press on this site. I have been doing conversions to MPEG for years and when I started using MINI DV I just about killed myself trying to get a perfect copy DVD from it and WinAVI seems to be the only way to do it. No other conversion can give you the quality. -
The thing is that I keep getting these 2.39GB filesets on different movies. This seems weird to me, almost like its a bug.
I don't know,
J. -
"Taking the mpeg conversion process out" is quite impossible if you are making a DVD from an avi. A DVD is an mpeg, no way around it, and it is in the VOB files that you burn to the DVD. There is always a loss in quality when you convert from avi to mpeg, but if you use a good encoder (TMPGEnc, CCE, Mainconcept etc.) and the proper settings then your output should be close to your source.Originally Posted by obiwan176
Sorry I can't help with winavi, I don't use it."Art is making something out of nothing and selling it." - Frank Zappa -
I understand that DVD is MPEG and that is what WinAVI converts it too, but it looks much better than anything TMPEG has ever given me. I have been using TMPEG for about 4 years, but as far as converting my Mini DV video to DVD the quality has never been close to the original. If you have perfect settings for it I am all ears but I have never seen super high quality video come out of that program. I have been stuggling with this because Mini DV video is great but transfering it to DVD loses too much quality. This should not be considering how good the original source is.
Hello,
Iam also ussung WinAVI 5.8.Is there any possebillety to convert an AVI to DVD directly whith subs? Like software as Cucusoft?
Krammie -
I have done something similar but found audio conversion from the original 5 channel to 2 channelsOriginally Posted by Krammie
I don't know if someone else experienced something similar
Expert advice needed regarding mpeg2 (ts) to mpeg4 (h264) encoding issue
By janvandenberg in forum Video Streaming DownloadingReplies: 16Last Post: 13th Dec 2011, 17:52 -
Advice needed on issue with AVI screen ratio
By Ric76 in forum EditingReplies: 4Last Post: 10th Aug 2010, 06:30 -
Help needed for video conversion : Winavi
By leoboms in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2010, 13:48 -
WinAVI 10 Authoring Issue
By Mr Mooney in forum Authoring (DVD)Replies: 10Last Post: 27th Jun 2010, 17:46 -
hdtv issue with dvd/vhs combo - advice needed !
By Dan of Troy in forum DVB / IPTVReplies: 3Last Post: 24th Nov 2007, 12:54
