When I convert AVI to DVD then playing the resulting DVD on the iMac is no problem. Picture is geat, sound is great. Same result when I play this movie on a Windows XP system. So apparently the DVD is in order.
However very often (better: almost always) when I play that same DVD on my standalone Pioneer (4 years old) player the first 3/4 has perfect picture and sound.
However toward the end there starts a cracling sound and in the picture there are these bocks visible and even sometime the playback is fully stopped.
On DVD's that I buy there is no problem.
Anyone suggestion to what could be the cause and how to prevent this problem?
your bitrate is to high (really)
A few questions then:Originally Posted by BJ_M
1. What is the maximum bitrate I should use?
2. Why does the problem only arise when nearing the end of a movie?
3. The problem also (sometimes!) arises when I use a conversion programm that I cannot control, being programs like Toast and similar?
Thanks for your replies. -
Sounds like crappy media. What kind is it?
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
yea -- could be crappy media also .. but if it plays ok in a PC , maybe not
max bit rate depends on the encoder your using -- 8000 is a safe max. ussually"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How do i share a video on youtube without it being blocked by copyright
By andresblinky in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Dec 2009, 01:59 -
Region Blocked DVD Players?
By Nitro89 in forum Off topicReplies: 6Last Post: 23rd Mar 2009, 18:26 -
High Resolution Playback Blocked
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 4th Mar 2008, 08:38 -
MTR ripdifferent.com blocked by Comcast
By missbibi in forum MacReplies: 7Last Post: 22nd Aug 2007, 20:31 -
new work Pc's,blocked internet
By nick101181 in forum ComputerReplies: 2Last Post: 16th May 2007, 19:32
