  1. I have a couple of movies that I would like to burn. The problem is that they are in two different file folders. Before I use Virtual Dub to extract the audio and TMPGEnc 2.5 to convert them and TMPGEnc DVD Author burn them...is there a way to conect these files together as one?
    If I say or post something stupid, please excuse me because I am a computer dummy. - Kaizen10366
  2. If you care to check the guides (link on the left hand side) you will have answered your question already.
    Good luck.
    It's time to kick some butts, and presto ( if you know what I mean )
  3. So, do I join them and then use Virtual Dub afterwords to extract the sound or do I extract the sound from both files before? I don't see this mentioned in any of the guides.
  4. you can join them in dvd2one,as seperate titles,or as 2 parts of the same movie,either is selectable from the title button either 1 or 2.
    Mar 2004
    Southern California
    What format are your videos in? TMPGenc dvd author (tda)can do what you want, if the video files are already dvd compliant. Try to load one of the videos in tda, if it opens you are home free, if not then you will probably need to encode. you can add your second movie in same or new title within the same project to get both movies on one disc. You can also create a menu. If you don't already have tda, you can do this with dvdshrink also (it's free). Plenty of guides to left.
