Results 1 to 9 of 9
  1. is there a way to convert mpg to dv?
    and lossless
  2. By this you mean to convert your MPG to DV without loosing quality... Well this is going to depend on the bitrate you use.... More Bitrate = Better quality, but more storage space needed...
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    DV is fixed bitrate -- there is not a lot of choice there ..
    install the main concept or panasonic Dv codec
    install virtualdubMOD
    open mpeg in virtualdubMOD and save it out as a dv file
  4. thanks. i give it a try
    im trying to do editing and i know mpg is not good for editing. i have main concept
  5. i dont see save dv... from file menu
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    hit control C and pick the main concept Dv codec
    hit F7 and save avi ..
    it will be a dv file ...
  7. i get an error
    cannot start compression
    the source image format is not acceptable
    error code -2
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    then your source files are not standard DV format --- which must be 25 or 29.97 fps interlaced (or with pulldown) and standard DV format size ..
    you will have to make some sort of adjustment .. also make sure you pick full proccessing mode
  9. VirtualDubMod still not working dv codoec, i think mpg is 29.97 fps
    i think im going to use flaskmpeg with huffyuv or picvideo mjpeg to converto avi
    should i use 640 *480 resolution?
    or 720 * 480
    the orginal source is 704 * 480
    and final will be 720 * 480
    thanks
