any programs?
Or use VirualDub -> Full Processing Mode -> Compression -> Use similar compression codec but now choose new resolution from codec Configuration -> Video Tab. Audio -> Direct Stream Copy. Finally Save As AVI...
Good luck
AndyWork you bloody thing.... -
I wouldn't use the codec's built in resize to resize it.
At the minimum, use Vdub's resize. Select Full Processing Mode (which will allow you to use filters). Then select Filters. The Filters box will open up. Select the resize filter and select precise bicubic. Then go into compression and set your codec parameters then save avi.
However, the best way to do it is to use AVIsynth to frame serve over to Vdub. There is plenty of info on how to use it, search for it. Look over the AVIsynth website, then look over the guides on www.Doom9.org then search the forums here and on Doom9
-Suntan
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Bigger resoltuion to smaller resolution
By cyberlion in forum EditingReplies: 16Last Post: 19th Aug 2010, 07:46 -
Lagarith codec producing larger filesize with smaller resolution?
By BozQ in forum Newbie / General discussionsReplies: 22Last Post: 15th Sep 2009, 11:11 -
Decrease the size of an avi file
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 12:51 -
Avi -> Smaller size
By gamerinha in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2007, 12:29
