I hope someone can help me with this problem?I ripped a movie using dvd decryptor,it gave me a video_ts folder with the vob files.I would like to know how do i convert this folder to a movie file that i can play off my harddrive?I do not wish to burn it just to be able to store it on my harddrive to play.![]()
you can play it with powerdvd or windvd or videolan. just choose to play a dvd from the hd and open the video_ts.ifo file. www.videohelp.com/play#dvd
if you want to make it smaller convert to divx or xvid with autogk or simpledivx or fairuse 0.44 -
Hello,
There is no conversion needed. Just use your dvd playing software (powerdvd, zoom player, etc) and open the video_ts.ifo {I believ} file and play it. The vobs inside the folder are the actual movie. The player will read the vobs on the hard drive.
Kevin
P.S. The software should read the main file for the dvd so it will play all of it. As a last resort you can play the individual vobs, though it won't be continous. Also you may need to select "open dvd files" or some such language instead of the media files selection of your particular dvd software.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
An idiot and a video_ts folder...
By CitizenErased in forum Newbie / General discussionsReplies: 11Last Post: 24th Jan 2011, 17:00 -
Converting a Video_TS folder into AVI
By HankE in forum ffmpegX general discussionReplies: 11Last Post: 6th Jan 2009, 15:48 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 14:39 -
How Can I Convert a DVD_RTAV folder over to a Video_TS?
By ginky4 in forum Video ConversionReplies: 2Last Post: 26th Feb 2008, 12:52 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 11:53
