Is this that fast at 480 Mbps?Originally Posted by gmatov
I saw that as Bus transfer rate and thought I saw this bit: Sustained Transfer rate as 34 Mbps and firewire at 41 Mbps.
Check out: http://www.maxtor.com/_files/maxtor/en_us/documentation/data_sheets/onetouch_data_sheet.pdf
I just found another mistake thinking that it is USB 2.0, it isn't as USB 1.1 at 12 Mbps as too slow.
I have use to another computer having that speed as USB 2.0 and this one got firewire as well. It is a notebook.
OR
Get new USB 2.0 installed in that PC I wanted to have the Ext HDD connected. I'll have to decide soon.
Results 61 to 87 of 87
I am a computer and movie addict
Installed on -
computer 1: 80G & 120G
computer 2: 4G & 250G
computer 3: 50G, 150G, 250G
computer 4: 10G, 200G, 250G
I also have a bunch of drives that aren't in a computer.
loose laptop drives: 3.2G, 4Gx2, 12G, 20G
loose regular drives: 10G, 120G, 200Gx2
loose SCSI drive: 50G, 80G
So total comes to 2067.2G of space. WOW!!! Now I know where all my money went. No wonder my wife gets mad every time I get a new Hard Drive.
She should be cheering you on. You are buying 160 gig for like 80 bucks after rebate. When you were a foolish spendthrift, like the rest of us, you were paying 400 for 2 gigs.
Same for RAM.
My main mach has 160, 120, 100, 80, 120 USB, 20 USB, 600 gigs.
No. 2 440 gig,
No. 3, just 1 160, no externals, yet.
So, 1.2 TB, so far. Not for long, though.
Cheers,
George -
If I were to average costs of how much I spent on my drives all together and including the cost to ship them, I think the cost would be around $.60-$.80 a gig. I usually get the drives, brand new, with a bunch of friends in a bulk shipment. the 200G and 250G drives were each about $90-$100 at the most. Seagate and Maxtor 7200RPM drives. I can't stand anything less than 7200RPM.
Main desktop
80GB(WD)
250GB(MX)
Server 1
73GB(FJ)(SCSI)
73GB(FJ)(SCSI)
Server 2
40GB(MX)(Boot/OS)
200GB(WD)
200GB(WD)
200GB(WD)
200GB(WD)
3 in RAID0 til i RMA the last, then back to RAID 5.
PC2
40GB(SG)
PC3
40GB(MX)
PC4
30GB(MX)
Laptop
60GB(Toshiba)
Externals
40GB FW
120GB FW/USB2
(I think that's it.)Nothing can stop me now, 'cause I don't care anymore. -
are you sure ?
Originally Posted by jimmalenko
haha -- was EXACTLY what i thought also ..
How'd you guess?Originally Posted by jimmalenko
Actually I don't even have a site.
Although every now and then when people ask me what I'm up to, the standard response is 'uploading porn to the internet.'Nothing can stop me now, 'cause I don't care anymore. -
With over a TB of storage and a 5Mb connection. I'm a bad man!
I'm also on PPPoE. Never really wanted to pay for DynDNS.
you can get DynDNS type service for free -- some listsOriginally Posted by ViRaL1
http://dmoz.org/Computers/Software/Internet/Servers/Address_Management/Dynamic_DNS_Services/
http://www.geocities.com/kiore_nz/subdomains.htm
http://dns.highsynth.com/
http://www.oth.net/dyndns.html
http://www.dyndns.org/ anyway is free also"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I have another 2X150gigs to add to my previous numbers. Got a couple of new seagate drives.
let see at home compt.
#1. Int. | | External
60 gb | | 250 gb
200 gb | | 250 gb
about 10 gb( not connected at this moment )
#2
60 gb
40 gb -
Add another 4x80gig. I'm getting some Maxtor Drives from my brother. Not big ones, but free drive space (Well, I have to pay for the shipping, but that's less than $30)
1 120GB Seagate
1 40GB Western Digital
Also got a 40GB Maxtor in my Playstation 2...man do I ever feel inadequate as far as my PC specs go after reading this. I'm curious, how big of a PSU are you guys using with this many hard drives? I'm thinking about modding my XBox, throwing the 40GB WD in there and picking up a 2nd Seagate 120GB HDD for my PC...orrr, I will be buying 2 120GB HDD's, one for my XBox, and another for my PC, and then run the 40GB WD in an Enclosure via Firewire. Anyone have a similar setup? -
I have 4 towers for my drives, but even then I have HDDs strewn in a closet like CD cases. They are all in anti-static bags, Of Course. All hell would break loose if I lost a 40gig drive with nothing but kazaa music downloads.
a good quality 600 watt is fine for a dual xeon with 10 drives and lots of cooling ... some video cards will need a bit more ---
its not hard also to use more than one power supply at a time -- simple mod to hook 2 atx together .. or use a older AT style for some drives ... make sure they all are on the same ground potential though .. and on the same phase on your mains ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
My porn isn't really MY porn. Not sure about the legalities.Originally Posted by jimmalenko
The last thing I wanna do is violate my parole again.
What size PSU do you have now? putting in a few extra drives shouldnt make a big difference you know if it doesnt power up if you need a bigger power supply.Originally Posted by DeleriumMDK
Most people have 300watt power supplies or higher and that should be just fine.
I want to switch my 40GB xbox HD to my ps2 and then buy a 200 GB drive and use in my ext HD casse (right now I have a 100GB drive in the case. that one that will go to my xbox) -
I've done the same thing for a couple of towers in the past. It's not hard to do at all. However, if you have time and money you can make a BPU (Base Power Uint). My own design and name. I took a mini-tower frame and with some engineering help from my father, created a circuit board design (Mostly beacuse he has an old aquarium that he uses as an acid bath and has other good equipment) to make a power supply that had around a 4000W capability. It's basically a creation of 6 identical PSUs at 650W a piece. The unit gets pretty warm, but we added a liquid cooling system that attaches to the heatsinks and it has 4X5" fans to aid the cooling. I only put enough cables on it to support 4 ATX motherboards, 30+ drives and has the ability to add connectors to plug a server into. The thing is a heavy a** mofo and I should have made a wheel assembly for it. It takes 2 people to lift it and it still feels like it weighs a ton. It was also pretty expensive to make, so I don't suggest anyone else try it unless you feel like investing in a fun hobby. I think I can still dig up the design plans for it if anyone wants them, but it is NOT HARD AT ALL to figure out on your own. I think it would have been a lot cheaper just to buy 6 identical PSUs, opened them up and bought new styles of heatsinks and parts. I'm also heavy into making new and funky designs of computers for ergonmic reasons. I'll throw a list of design ideas and things in another thread.Originally Posted by BJ_M
XP Ho won't see the other drive where Windows 7 is installed (in dual boot)
By edong in forum ComputerReplies: 3Last Post: 29th Dec 2011, 16:05 -
What type of hard drive do you have your o/s installed on?
By johns0 in forum PollsReplies: 11Last Post: 21st May 2011, 19:31 -
Replaced defective Drive (O:) Installed New HD and Can't Rename it (O:)
By cplevel42 in forum ComputerReplies: 8Last Post: 16th Oct 2009, 12:25 -
CD storage on hard drive player.
By hiliftjack in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2009, 13:26 -
Win XP installed on slave drive!!! How???
By rijir2001 in forum ComputerReplies: 7Last Post: 4th Sep 2007, 10:25
