Craig runs a Top Site it appears :P
Results 31 to 60 of 87
Originally Posted by BJ_M
I don't get it
jesus, I feel like a lightweight...
260Gb (120 + 80 + 80), 4 partitions, about 100 free space across all 4.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Originally Posted by Craig Tucker
Top Site = high level warez ftp sites with lots of storage and fast connections .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Oh I see, not really down with warez speakOriginally Posted by BJ_M
Machine 1:
80GB
80GB
80GB
200GB
200GB
Machine 2:
40GB
40GB
120GB
Machine 3:
160GB
160GB
Machine 4:
80GB
80GB
Machine 5: (this one....my web surfing box)
4.3 GB
Total:
1324.3 GB"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Well my first ever PC I had 600MB on a sweet 486 Compaq all-in-one!!!! (Built in monitor) I remember thinking, What the hell would anyone ever need 1GB of space for??
Presently I have 2 Internal HDs (250 & 80 GB) and One External (160 GB) 490 GB Total. -
My main boxes ATM have:
PVR (comp for recording/playback tv crap only):
1x 120GB
1x 6GB (yes, six GB
Box for games:
1x 40GB
This box:
1x 2.1GB
I have other drives on various computer I use or dont use at home, all in total of ~1TB
At work I have probably almost infinite amount of space (lets just say I use few machines running on different intranets, where all drive letters are already taken on few of them
3dvr, 520gb.
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
You feel like a lightweight! I have two drives 40GB and 30GBOriginally Posted by housepig
Wrap the tape firmly around the hamster... -
40Gb O/S drive (IBM)
120Gb Capture drive (IBM)
120Gb Editing drive (IBM)
120Gb Ripping drive (IBM)
120Gb Storage drive (WD)
200Gb Storage drive (WD)
250Gb Ext firewire drive (Maxtor)
970Gb Total
Got about 100Gb free because since January, all the TV caps I've done I've encoded for authoring on DL DVDR but haven't bought a DL burner yet (disks cost waaaaay too much
Regards,
Rob -
PENT 4 PC-
internal hard drives- 60 GB, 120 GB, 200 GB in a mobile rack
external firewire hard drive - 120 GB
total 500 gbs
PENT 3 PC-
internal hard drives- 40 GB, 60 GB
total 100 gbs
All Maxtor Hard Drives, the 200 GB was only $104.00!!!!!!
The only external firewire hard drive I have does works well. I haven't had any problems with it. Purchased it from COSTCO for $165.00 4 months ago.
I'm called a krazy nut for having so much hard drive space.
At Home
100Gb+
80Gb+
60Gb+
40Gb+
4Gb=
284Gb
-------I am a computer and movie addict -
Brand new home machine = 160GB
now we know what happened to that missing harddrive from the lab ..
Good oneOriginally Posted by BJ_M
Shhhhhh, quiet. They don't know I have it
2 x 120 gig units in the computer, a USB 2 external with 120gig soley for scripted backup on boot.
A Slave computer on 100meg network connection with 3 x 80gig internals mapped for storage -
Home network
Main PC XP
120
250
G5 dual 2g
120
200
Xbox home
80
Xbox in car (I run a cat5 to the driveway to keep 20 current films on it)
120
Laptop
12 gig laptop
old 266 mhz or so slave for backups:
+120 backup for pc
+120 Back up g5
+160 misc on old slave
+250 gig external usb fw
about 1.5 tb
1.25 with dedicated backup subtracted
yeah, its nuts. -
Can't go very far in the car thenOriginally Posted by aero
Hi all,
I am thinking of getting an external hard drive, 120GB capacity drive. I noticed one advertised as having USB 1.1 and USB 2.0 support.
No mention on firewire connection?
The brand is Maxtor and I don't know about the make?
Will the USB be slow in the data transfer rate? Will it be worse than the LAN speed of 100 Mbps.
Is it possible to have hardware problems or errors using the external drive?
The PC is on Win2000 and the USB as a 2.0 speed. It is P4, 2.0 Ghz CPU speed. Let me know of any suggestion?I am a computer and movie addict -
ChrisX,
I would guess that the external is bound to be slower, regardless of the specs on the interface. An exception to that might be a rip-roaring external SCSI drive, but they'll set you back some serious money for the interface and the drive
you have a number of options. you can find most hard drive manufacturers offering external drives in several capacities. they will all have usb2.0 and some will have firewire (for which you will pay more)Originally Posted by ChrisX
these ready made external's have a premium of about $100 or so from the cost of the bare drive. If you have ever swapped a drive you know enough to buy an external enclosure for about $30 and save $70 or more with ten minutes work.
In terms of speed, I dont have the stats, but they an be prettty fast and fast enough for most applications.
finally on errors, a couple of hints should eliminate them.
1) don't dropp the enclosure too often
2) seriously, DISABLE write cacheing if you plan to disconnect the drive on a regulatr basis. If you plan to keep it hooked up most of the time, the write cacheing will give you faster speeds, but will expose you to problems if you just disconnect the drive without using the "saftely reomove hardware" option on windows usb
3) especially if you leave write caching, make sure to use the "safely remove hardware" and you should be fine.
Keep in mind large externals are very good for backups as you can keep it stored away from your machine. hard drive failures are one thing, but other data loss includes theft of your pc (expecially laptops), fire, or other catastrphic loss, an exteral backup stored away fromt he pc gives you much better protection.
there are also now networked usb ports that allow you to plug in usb components (especially drives and camera's) on your network independent of your pc,. those are nifty as well. -
530GB, or as I like to put it to impress the ladies, "my harddrive capacity is somewhere north of half a terabyte." They swoon every time.
I actually hadn't counted up all my hard drive space in a while and I buy 200 or 250 GB drives every month or so.
Workstation 1:
74GB SATA boot
200GB PATA storage
147GB SCSI scratch
PATA swap
Workstation 2:
74GB SCSI RAID boot
360GB SCSI RAID only 10k drives tho
PATA swap
Internet 1:
120GB PATA boot
80GB PATA scratch
200GB PATA storage
PATA swap
Mobile 1: (not the oil)
40GB PATA laptop drive
PATA swap drives:
5x 200GB
3x 250GB
1x 80GB
2x 160GB
FireWire storage:
40GB bus-powered
120GB
160GB
Totals:
3110 GB PATA
74 GB SATA
581 GB SCSI
3765 Total disk space
Huh, almost 4TB of storage at home. Wish more if it were SCSI but the secondhand drives are harder to come by these days. More home/power users must be getting into it. At work I think I only have 1TB total space, but I don't do video work there so it isn't much needed. The range of computer technology is astounding though. There is a working 486 within 15 feet of our new G5
Hey! ASCI RED doesn't count!Originally Posted by Capmaster
I am running a meager 150GB on four separate drives. But, to compensate, I run four DVD burners, four CD burners, and enough blank rewritables to open my own online media store...I'd guess about 1TB. -
Thanks for your advice and very much appreciated.Originally Posted by aero
The biggest Ext HDD I can see is 300 GB and having firewire can be expensive as I found out on my enquiry.
I also found the data transfer speed can be fast however not as fast as the LAN.
My network speed is at 100 Mbps.
I've seen basic Ext HDD specs suggesting at around 35 Mbps to 40 Mbps. This is a little slow compared with the LAN speed. This is ok though.
I am worried on the safety of large amount of videos and music in the PC and as they are so large I can't backup in the DVD burner. I can break them into several DVD-R discs though.
I am still not sure whether to go ahead with the Ext HDD and I am more incline to have an internal drive instead as 160 GB Drive 'E'?
I can still buy the Ext HDD just to protect my data as you say for emergencies.
Anyway, the USB connection isn’t a problem at all as the PC got 4 ports available.
I have to make up my mind on this and will contact my PC specialist for another advice.
BTW, I still haven't got a DVD burner in the PC yet and a good time to consider options.
This PC currently got three removable storage drives and this includes a floppy disk drive.
I am getting rid of the old DVD-ROM due to region restrictions and music CD playing problems having copy protection on them. This is ridiculous.
Anyway, thanks mate.I am a computer and movie addict -
Chris,
You are a little mistaken, there. Granted your networked at 100mbps, that's mega BITS per second, your USB2.0 is rated at 480 mbps, that's mega BITS per second, 4.8 times as fast as the network.
Your network thru put can be 12 1/2 mega BYTES per second, your UDSB 2.0 at 60 mega BYTES per second.
And your videos at 3.6 mega BYTES per second.
You have all the headroom in the world.
Buy what you can afford, can hook up. If you are comfortable inside the box, buy a 300 internal. If you are not, buy a 300 external.
Simple.
Cheers,
George
XP Ho won't see the other drive where Windows 7 is installed (in dual boot)
By edong in forum ComputerReplies: 3Last Post: 29th Dec 2011, 16:05 -
What type of hard drive do you have your o/s installed on?
By johns0 in forum PollsReplies: 11Last Post: 21st May 2011, 19:31 -
Replaced defective Drive (O:) Installed New HD and Can't Rename it (O:)
By cplevel42 in forum ComputerReplies: 8Last Post: 16th Oct 2009, 12:25 -
CD storage on hard drive player.
By hiliftjack in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2009, 13:26 -
Win XP installed on slave drive!!! How???
By rijir2001 in forum ComputerReplies: 7Last Post: 4th Sep 2007, 10:25
