here is mine right now (19 drives) ...
230-|=====================DRIVES STATS=========================
230-|
230-| Drive:C:\ Total [32.03 GB] Free [12.40 GB]
230-| Drive:G:\ Total [111.79 GB] Free [24.32 GB]
230-| Drive:H:\ Total [111.79 GB] Free [6.33 GB]
230-| Drive:I:\ Total [111.79 GB] Free [26.48 GB]
230-| Drive:J:\ Total [111.79 GB] Free [22.73 GB]
230-| Drive:P:\ Total [34.18 GB] Free [26.65 GB]
230-| Drive:Q:\ Total [223.58 GB] Free [14.44 GB]
230-| Drive:R:\ Total [372.62 GB] Free [152.99 GB]
230-| Drive:S:\ Total [372.62 GB] Free [254.64 GB]
230-| Drive:V:\ Total [152.66 GB] Free [26.25 GB]
230-| Drive:W:\ Total [372.62 GB] Free [101.34 GB]
230-| Drive:X:\ Total [372.62 GB] Free [1.01 GB]
230-| Drive:Z:\ Total [372.62 GB] Free [99.16 GB]
Results 1 to 30 of 87
50 Internal only.... tgpo, what are you using for your external (my next investment)Originally Posted by tgpo
look at my computer profile
If we're including network drives, I have about 400 terabytes attached, as well as 6 teraflops-class supercomputers including four Crays, a Paragon, and a 2150-processor massively parallel machineOriginally Posted by BJ_M
No kidding, If we're talking network drives, I have all I need. If I run out of place, I just order some more.Originally Posted by Capmaster
True. For home network, not really that much, about 500G between all the machines. At work.....more than even I can imagine since we have several servers dedicated to customers uploading massive video files!
Yeah, that's my work machine. My setup at home is a little more modest - 20GB on one laptop and 30GB on the other
Different funding source too
no -- not network .. just main work or home computer internal storage ..
external network .. i dont know how much but it is a lot ...
governments and universities and nuclear research facilities need not reply ..
At Home
60Gb+
60Gb+
60Gb+
80Gb+
40Gb+
30Gb+
30Gb+
30Gb+
15Gb=
405Gb
Probably about 3/4 full most of the time.
Work, about 10Tb, about 1/2 full last time I checked. -
How do you get the "Drive Stats"?Originally Posted by BJ_M"Terminated!" :firing:
Couldn't resist
At home -
80GB + 120GB Internal.
80GB External
At Work
T:\ 50GB
U:\ 25GB
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Originally Posted by thayne
i log into my ftp server running on my computer - which is running a
log-in script (blackmoon)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I didn't think they made drives that were 372.62 GB???Originally Posted by BJ_M
You have 5 drives listed at 372gb in size...SCSI RAID right?
62gb or 73gb HDD = 6 or 7 on a chain x 5 = 30 - 35 HDD at $150.00US =$4500 - $5200
or did I miss something -
A maxtor HD in a standard case.Originally Posted by DVD_Ripper
I have only 1 hard drive
but it's 200 Gb, so it's okay. even though I only have about 15Gb of space left.
this computer, a 140 and a 70 SCSI. the computer next to me, raid 5 with 203 gb. home network i'm on, another raid 5 with 300 or so gb's.
120GB + 80GB so 200GB.
400 GBytes internal (2 160GB and 1 80GB).
I have two 20GB external on a USB 1.1 port. Needless to say, the external drives are only for transporting files (approx 1 MB per sec transfer speed).ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by stiltman
19 drives total
the 372.62 GB are 2 x 200GB raided
just that 400GB worth of drives are reported as 372.62 GB"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
My Current setup:
Seagate 160 GB SATA
Seagate 120 GB SATA
WD 120
IBM 80GB (for system drive).
The above 3 drives are for my AV storage.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
Drives are like dvd's. my drive is called a 200Gb hard drive, which means its 200,000,000,000 bytes which works out to about 186 actual gigabytes.Originally Posted by BJ_M
5 drives, total 690GB
XP Ho won't see the other drive where Windows 7 is installed (in dual boot)
By edong in forum ComputerReplies: 3Last Post: 29th Dec 2011, 15:05 -
What type of hard drive do you have your o/s installed on?
By johns0 in forum PollsReplies: 11Last Post: 21st May 2011, 18:31 -
Replaced defective Drive (O:) Installed New HD and Can't Rename it (O:)
By cplevel42 in forum ComputerReplies: 8Last Post: 16th Oct 2009, 11:25 -
CD storage on hard drive player.
By hiliftjack in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2009, 12:26 -
Win XP installed on slave drive!!! How???
By rijir2001 in forum ComputerReplies: 7Last Post: 4th Sep 2007, 09:25
