I am trying to burn CD-R's on my DVD Burner. I use Nero 6.
Everytime I try to burn my wav files it spits out my CD-R.
I tried to copy from CD-R to CD-R and it won't let me. I keep getting the message to put in a blank CD-RWhich is what it is.
I copy and burn DVD-R's fine.
Please help.![]()
Hello,
I don't use nero but here's a suggestion. If you can burn dvds fine is there a selector for which type of disc it is? Make sure when your doing cdrs you have the blank media type set to cdr (74 or 80min). Hope this helps.
The only selector I know is in Nero, select DVD or CD. Is there another the select a type of media
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 12:34 -
BDMV burning problem
By rickoshay in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jun 2010, 05:48 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
