i am interested in trying ffmpegX's dvd>4Gb option under tools to compress my video_ts folder which is 7GB or so. But I guess i need to take all the vob files in this folder and make a single vob out of them that would then be greater than 4Gb? I take this vob and then enter it into the browse field in ffmpegX's tools section and click on dvd>4 button to produce the copressed vob. Is that right?
The only problem is of course how do i make a single vob out of all the vobs in my video_ts folder? FfmpegX will not accept the deencrpyted video_ts that i have for compression via dvd>4; it wants a vob and wont accept those that are less than 4G in size. So do i join all the vobs in the video_ts folder first using the join button under tools in ffmpegX? why is there not more documentation on this method of compression in ffmpegX's manual and other documentation? I know that using dvd2Xone is of course the best method for compression, but i was hoping to try ffmpegX and am missing some understanding to do this in this way.
thanks,
t.a.b.
Results 1 to 14 of 14
Use 0SEx for that[/quote]Originally Posted by tab75-13
there doesn't seem to be a way in OSEx for selecting an already decrypted video_ts folder, only a disc, unless i am not seeing something. i looked under opts and read the readme and am still unclear as to how to select the video_ts in order to make that single vob. i have OSEx 0.0101. Thanks for your reply, but can i do this without having the disc on hand?
thx.
t.a.b
OK, You probably want to make a vob of the main feature in the DVD folder, that's the one with the most vob files, so you use the terminal, let's say it is title 1 you wanna join:Originally Posted by major
Instructions in red, the stuff you should write in the terminal in black.
cat drag VTS_01_1.VOB into the window and do the same with 01_2 etc. > mymovie.vob
cat drag VTS_01_1.VOB into the window and do the same with 01_2 etc. > mymovie.vob[/quote]
Do I hit enter after typing in cat and then insert the vobs starting with vts_01_0.vob all the way to the end of the main feature? or do i hit enter after having typed in cat, inserted the vobs typed ">mymovie.vob" and then hit enter? because when i do the latter i get command not found. if i do it as described the first way, hitting enter first after "cat" and then after having inserted all the vobs starting with vts_01_0.vob to the last one and finally again after ">mymovie.vob," i get the repeat of the line "mymovie.vob" without quotes and nothing else like terminal is doing some thinking etc.
so i guess i am doing something wrong. where by the way is the resulting vob supposed to end up if i am successful in producing that massive file?
thanks,
t.a.b.
You hit Enter after > mymovie.vob ONLY
thanks,
t.a.b.
So to spell it out the precedure is:
WRITE: cat BLANK SPACE
DO THIS: Drag the VOBs into the terminal window in the proper order
WRITE: > mymovie.vob ENTER
And a joined VOB will be created in your home folder.
Thanks. followed your instructions and they worked producing a 6.6 G vob of a main feature that i am currently attempting tocompress using the dvd4 button in ffmpegX. It's been going about 45 minutes now and i don't know how long it will take; i'll leave it overnight i guess. for the purpose of this particular video_ts folder in extracting it using mactheripper i selected only the main feature so i have vts1... files only; for a different extraction, however, the vts files start beginning with 2 . if i want to create a vob of the entire content of the video_ts folder containing this set of vobs, should i stick with only the 1st set of vts files, and disregard the other ones? if i include the other ones, i.e., those next in the series, vts2 etc., will that screw up the reulting vob?
well, while i was writing this the process seems to have failed. I got his error in the information. any ideas?
**ERROR: [mplex] Need to split output but there appears to be no %d in the filename pattern /Users/tabeerbadar/mymovie.vob.4.mpg
thanks for any more help you could give me here,
t.a.b
t.a.b
ok here's the entire process log. i hope you wont mind. at the end is the error mentioned before.
M2VRequantiser by Makira.
Using 1.630085 as factor.
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/tabeerbadar/mymovie.vob.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/tabeerbadar/mymovie.vob.ac3 looks like an AC3 Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/tabeerbadar/mymovie.vob.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 8000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: AC3 Audio stream 00 (/Users/tabeerbadar/mymovie.vob.ac3)
INFO: [mplex] AC3 frame size = 768
INFO: [mplex] AC3 AUDIO STREAM:
INFO: [mplex] Bit rate : 24576 bytes/sec (192 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 8320800
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Scanned to end AU 0
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio bd: buf= 16384 frame=000000 sector=00000000
INFO: [mplex] Running out...
INFO: [mplex] Video e0: buf= 235556 frame=000000 sector=00000001
any ideas?
thanks.
tab
if i use the DVD preset to reecnode the video_ts folder, how will i load it into OSEx, because OSEx seems to accept only discs?Originally Posted by major
2) if there's way to introduce the reencoded video_ts folder into OSEx, how do i get it to regenerate a vob, or does it do that by itself with you having to indicate to it to produce a vob and not another video_ts folder the way other rippers do?
thanks again and sorry if i sent a double message last time.
tab
well after reencoding for approximately 26 hrs, ffmpegX using the dvd preset did produce a .mpg, .mpv, an .mpa, a .img, and a dvd folder containing the video_ts and an audio_ts folder. I did not have the mpeg-2 player component in quicktime so i had to select the mplayer option for decoding. I tried to play the resulting compressed video_ts player. The video was jerky and there was no sound. Could the lack of sound be due to the fact that i had an unidentifiable, i.e., gray, .mpa elemetary audio stream file from which to mux the video_ts folder? (if i wanted to rename this file w/ an .ac3 extension, it would change it and the resulting vlc icon would identify it.) ALso why the jerky video? due to having decoded with Mplayer as opposed to Quicktime?
if i had the quicktime mpeg-2 component installed would it have reencoded quicker than the mplayer and might it have given the audio in the resulting vieo_ts player as well?
finally, if i renamed the .mpa gray file as an .ac3, it does play in vlc, so it does have the entire audio of the film.
i haven't checked the resultant mpeg-2 file, but i assume it will lack the sound.
i'd be grateful again if you could please help me with these problems that arose in this experiment.
thank you,
t.a.b.
p.s.
checked the .mpeg2 file in vlc as well as the resulting video_ts player there. both played with sound and no discernable jerkiness to the video. i wonder if this will play in a standalone dvd player? i then retried the apple dvd player for this compressed video_ts folder. still no sound and jerkiness present in the video. i have tested the apple dvd player with the original video_ts folder and it plays that. so what do you think if you don't mind me asking?
thanks,
t.a.b
How to change single VOB file to VIDEO_TS folder
By skyllasibe in forum Newbie / General discussionsReplies: 10Last Post: 9th Jun 2013, 06:02 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 12:14 -
Convert VIDEO_TS folder into a SINGLE AVI file
By donkeyking in forum Newbie / General discussionsReplies: 6Last Post: 29th Apr 2010, 16:32 -
VIDEO_TS folder to single sized file possible?
By THX-UltraII in forum Video ConversionReplies: 3Last Post: 5th Feb 2009, 02:32 -
single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
By jabroni5 in forum ffmpegX general discussionReplies: 15Last Post: 7th Jun 2007, 17:48
