  1. Member Flarch's Avatar
    Apr 2004
    E68°50'15.2" S49°11'12.6"
    Searched, but threads were somewhat old and not quite what i was looking for.
    Received an MPEG 1 all set up for VCD as far as dimensions, bit-rate, audio rate, etc. Plays just fine.
    I wanted to remove some material, add some simple chapters, and burn a VCD.
    I used mpgtxwrap to chop it up a bit which seemed to work nicely. All pieces played clean.
    I usually use VCDBuilder when i want to quickly toss MPEG together with my own splash, and add chapters. It allows no choice but to have a chapter at the beginning of a sequence so i decided to join the kept pieces back together.
    I tried using mpgtxwrap to join the pieces, but when i played the result, the join points were garbled. I retried joining with ffmpegx and they were cleaner, but still very rough for about 1 second. Lots of wonderful little flickering boxes.
    I'm going to attempt putting multiple pieces into a sequence and see what VCD Builder comes up with, but does anybody know a sure way to wind up with a VCD having clean transitions between segments? Preferably just a way to cleanly edit MPEG 1 files that have matching characteristics.
    I've also been seeing the occasional report from VCDBuilder that segments were "unaligned" and that huge amounts of padding were going to be added. As a relative newbie, i'm not clear on this alignment business.
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    i never edit in MPEG as i capture in DV. everyone here seems to like womble mpeg VCR though....
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    do you still have the "large" single source you were "chopping" to bits?
  4. Member Flarch's Avatar
    Apr 2004
    Yes, I do still have the original MPEG 1 video file.
    Is this transition thing a header problem?
  5. Member Flarch's Avatar
    Apr 2004
    Wow. Frame accuracy. Yay!
    microslough weendoze only. Booo!
