alright iam doin a pal to ntsc conversion using tmpgenc and Iam using the template ntsc film, so I know all the settings are right under the video tab, under the advanced tab the source is nob-interlaced/progressive and I chose do not frame rate, know what I need to know is this, there is an option called inverse telecine under the advanced tab know when iam doing a PAL to NTSC conversion is there any reason why I should check this option/filter and use the auto-setting to set it to some specific seting like 24fps: Flicker prioritized or 30fps: Flicker prioritized? Should I mess with this option at all?
Ok my next question when doing a pal to ntsc conversion is there anything I have to set or change on the gop structure or the quantize matrix?
-Jay
IVTC is for going 29.97 to 23.976, you're going from 25 to 23.976, so leave it alone!
NTSC GOP can be 18 frames rather than PAL 15, don't forget to set 3:2 pulldown on playback. quantization matrix can be left as is.
How to convert a PAL DVD to a NTSC DVD using TMPGEnc Plus 2.5x
By FulciLives in forum User guidesReplies: 266Last Post: 21st Jul 2018, 05:16 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 12:59 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
