I have aproblem here. Have a file size o 3.5 gig mpeg2 with audio AC3 and a small file of 50 MB mpeg2 with audio mp2. Both files are DVD complaint and TMPGenc DVD Author accepts seperately. But what I want to do is make one DVD with both files using TMPGenc DVD Author. As the audio format is different TDA will not accept both files together. Therefore how can I change the audio of small file from mp2 to AC3 without doing any change in the video section.
Please help me
Each can be in a separate track. Is that okay?
If not, demux the audio/video and convert the audio on one of them, using BeSweet with the GUI.Want my help? Ask here! (not via PM!)
or get the tmpgenc dvd author ac3 plugin if you want dvd compliant ac3 audio.
To get them to play without any pause, you'll need to have, what's called, seamless play. That depends on how the videos were encoded (type and bitrate). Plus TMPGEnc DVD Author needs to be capable of authoring seamless play when you add two videos to the same track (I haven't used it that much, but I don't think it can).
So it may not be worth it. You may reduce the pause by putting the videos in the same track, as opposed to having them in separate tracks, but you'll still have a pause. Unless someone knows how to get seamless play in TDA.
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
