I just renammed a file (which was not a video file) with the extension of .MPG and now it is a video file but of course wont play. But how do I get rid of the extension? cause the text in the name of .MPG isnt there now. The file is just changed into an MPG. HOW? HELP?
Phew! Calm. Sorry, found me answer. Should have looked.
#1. open a folder any folder just open one.
#2. at the top of the folder click "Tools" then go to "Folder Options"
#3. go to the "View" tab
#4. take the checkmark out of the box next to "hide extensions for known file types". -
If I understand your post correctly, you need to go into the tools menu in 'my computer' and click on folder options. under the view tab, uncheck "hide extensions for known file types". then all the file extensions will be displayed and you can change them.
"hide extensions of known file types" is a stupid option. It should be eliminated from the face of the earth.
What is a r4m and r4s file extension?
By ravens4life in forum AudioReplies: 1Last Post: 29th Feb 2012, 20:35 -
J4F file extension
By mariestalet in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2009, 04:53 -
New File Extension To Convert
By EDS001 in forum Video ConversionReplies: 6Last Post: 20th Mar 2009, 17:59 -
Converting to new file extension
By Nitro89 in forum Video ConversionReplies: 11Last Post: 17th Apr 2008, 13:42 -
wht is the .ff file extension
By modular1 in forum ffmpegX general discussionReplies: 3Last Post: 9th Oct 2007, 06:05
