i am using Sonic MyDVD to author a DVD, its easy to use, and i have a movie in two files, same dimensions, codec, audio, everything, is there a way in the program to make it one title? thanks
A DVD created by Sonic MyDVD will play the video files sequentially (with or without a menu). My experience has been that each video file becomes a separate title. If your version includes Arcsoft Showbiz, I think you can join the two files, effectively creating one title.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
oh yea, i forgot, that came on the disc. can that also resize videos to the right size for and NTSC video?
Arcsoft Showbiz includes the option of NTSC or PAL.
George Carlin
Re using old Sonic hardware - little help?
By Pentos in forum Capturing and VCRReplies: 9Last Post: 17th Oct 2012, 10:34 -
Roxio MyDVD menu display
By moviegeek71 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2008, 21:03 -
Why cant i change audio output in MyDVD 10
By LiBiDoXP in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2008, 01:16 -
large file size when importing small video clips into Sonic MyDVD
By artistream in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 19:48 -
Limited background Audio in MyDVD 9
By cmblocker95 in forum Authoring (DVD)Replies: 0Last Post: 6th Jun 2007, 15:21
