I'm looksing for a joining program that can apply transitions such as fade to the in and out of clips, can seamlessly join DV-avi files and export to DVD compliant mpegs files. Tmpgenc is the closest, but it doesn't come with transitions. Everything else doesn't support mpeg2 or at the least doesn't do a very good job of it. What would you guys and girls suggest?
Thanks!
DiMarco.
I tried Womble, and it did just what I wanted, cept the video was streched on the tv when I encoded it... something I've NEVER experienced before. I even used the dvd template, and the video size was the same as my source. Any ideas?
well, if your just trying to combine some videos with transitions, like i said, go with Arcsoft Showbiz, it also automatically fits it to a normal tv size
What is Best Software for Slideshow Presentation Videos? Cool Transitions !
By zcity1 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2011, 13:11 -
Looking For Software to Create Menu- w/ Fade Transitions Between Chapters
By restmin in forum Authoring (DVD)Replies: 2Last Post: 13th Apr 2011, 16:36 -
Adding transitions to videos with free software
By Cyber Akuma in forum EditingReplies: 61Last Post: 8th Dec 2010, 11:36 -
Help: .m2ts joining and adding transitions
By klynax in forum EditingReplies: 2Last Post: 9th Oct 2009, 14:25 -
Joining files software
By XDPD7 in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2008, 22:15
