It is another way to smooth your source.
Personally, I didn't test this method, but years ago, I read and did myself a similar test: I captured a VCD again analogue from my standalone and I re-encode it to VCD. It looked better than the original VCD that way. Then, I realise that this happened because of the smoothing my standalone done to the VCD, plus the adjustments my capture device and the software I used succeed automatic to produce, for enchancing the pictrure.
Then, I filtered my original source and I had the best results of all those attemps.
I conclude that when you learn how to use the filters (and in which order), you can succeed far better results any other way. But this is the hard way: You need to read, test and learn many things. People tend to do stuff that feel easier, and reading / testing isn't the easier thing. Hook one device to another, roll couple of thing you stuff and end up with something that seems good, is actually easier for them. -
Originally Posted by SatStorm
help with capturing from various analog devices
By TARfan in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2010, 11:36 -
Capturing audio from analog tape - use NR or no?
By sphinx99 in forum AudioReplies: 5Last Post: 6th Mar 2010, 22:47 -
going CRAZY: capturing with ATI HD 3600 (analog)
By nuzumaki in forum Capturing and VCRReplies: 6Last Post: 13th Jan 2009, 17:24 -
How do you synchronize capturing two analog video sources?
By yoda313 in forum Capturing and VCRReplies: 7Last Post: 22nd Oct 2008, 13:17 -
Need some help capturing Analog video
By zagorski in forum Capturing and VCRReplies: 5Last Post: 10th Dec 2007, 19:27
