My friend has CCE and uses the program when ripping his dvd's for personal use.
If CCE does what I think it does, which involves passing the dvd numerous times to create a smaller file size, yet keep similar quality?
I would like to know if I were to take my dvd's, use CCE first, then proceed encoding my dvd to xvid, would I be able to get a higher bitrate by doing this? Rather than taking the orginal (without using cce) and encoding.
Something about the whole 'compressing/passing' makes me wonder if it'll work? After using cce, are the files different?
CCE is an MPEG encoder, you friend is taking an 8 gig dvd and throwing away half the data to make it 4.3 gigs so it'll fit on a DVD-R disc.
This won't help you encode Xvid at all, you're just starting the same process with a lower quality file, giving you ultimately a lower quality Xvid.
if you want your Xvid a higher bitrate, then, uh, increase the bitrate when you encode.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
