Video : 866 Mb, 1010 Kbps, 25.0 fps, res. 640*288 (2.21:1), DX50 = DivXNetworks Divx v5, Unsupported
what codec do i need for this to playback ok
for some reason, i cant find one to do this
cheers
you didn't install it from a codec pack did you? try a fresh reinstall of it or even Divx Light from the tools section. you can also try ffdshow. if none of that works you have some serious issues with the codecs on your PC.
divx light is no longer available due to legal issues - sadly
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 13:15 -
Problem with convertion to xvid...
By zovx in forum Video ConversionReplies: 11Last Post: 11th Feb 2010, 07:43 -
MKVTools and Xvid problem
By Geiger9 in forum MacReplies: 5Last Post: 18th Jun 2009, 16:34 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 12:25 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
