I've been burning 100's of dvds with no problem and all of a sudden i am getting tons of write errors. All I have done was move apartments and unhook and reset up my computer. I was using nero, but tried downloading other programs and had the same problems with them. it writes a lot of the dvd, but then gets an error midway through, not always at the same point. I have tried different media, different files, different programs, etc. This leads me to think it might be the burner. It is also having some problems reading dvds that it has never had before. It is an NEC 2500 and is only a few months old. Anyone have any suggestions. I included the log from nero below in cas esomething in there says something important, i can't understand it. Thanks!
-Jed
1A20-0100-0000-1531-6425-7605
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/16/2002 9:03:20 PM
ahead WinASPI: File 'C:\Program Files\Nero\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 9:25:03 AM
Nero version: 6.0.0.28 (Nero Express)
Recorder: <_NEC DVD_RW ND-2500A> Version: 1.06 - HA 1 TA 1 - 6.0.0.28
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <LITEON DVD-ROM LTD163 >Version: GDHG - HA 1 TA 0 - 6.0.0.28
=== Scsi-Device-Map ===
DiskPeripheral : ST360015A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITEON DVD-ROM LTD163 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
LITEON DVD-ROM LTD163 D: CDRom0
_NEC DVD_RW ND-2500A E: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523268kB)
Free physical memory: 116MB (119548kB)
Memory in use : 77 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.7.2004
UDF/ISO compilation
3:23:27 PM #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
3:23:28 PM #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
3:23:28 PM #3 Text 0 File Isodoc.cpp, Line 6024
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
3:23:28 PM #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
3:23:28 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
3:23:28 PM #6 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-2500A running
3:23:28 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
3:23:28 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3882
3:23:28 PM #9 Text 0 File Burncd.cpp, Line 3128
Turn on Disc-at-once, using DVD media
3:23:28 PM #10 Text 0 File DlgWaitCD.cpp, Line 237
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 1658271 (368:30.21)
3:23:28 PM #11 Text 0 File DlgWaitCD.cpp, Line 242
Write in overburning mode: FALSE
3:23:28 PM #12 Text 0 File DlgWaitCD.cpp, Line 2043
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R
Disc Manufacturer: BeAll - G40001
Disc Application Code: 64, Disc Physical Code: 193
3:23:28 PM #13 Text 0 File DlgWaitCD.cpp, Line 403
>>> Protocol of DlgWaitCD activities: <<<
3:23:28 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 775
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1658272 (1658272) = #1658272/368:30.22
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1658272 blocks [_NEC DVD_RW ND-2500A ]
3:23:28 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 944
Prepare recorder [_NEC DVD_RW ND-2500A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3396141056, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1658272 | lead-out | 1 | 0x00 | 0x41
3:23:28 PM #16 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
3:23:28 PM #17 Text 0 File Burncd.cpp, Line 4095
Cache writing successful.
3:23:28 PM #18 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
3:23:28 PM #19 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5,520 KB/s)
3:23:28 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2167
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:23:28 PM #21 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 10:23,616 (623616ms) -> OK
3:23:28 PM #22 Text 0 File DVDR.cpp, Line 1259
Recording mode: Sequential Recording Mode
3:23:28 PM #23 Text 0 File Mmc.cpp, Line 19362
Set BUFE: JustLink -> ON
3:23:28 PM #24 Text 0 File DVDR.cpp, Line 1374
Start write address at LBA 0
DVD high compatibility mode: Yes
3:23:28 PM #25 Text 0 File Cdrdrv.cpp, Line 7912
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
02 FE 10 00 02 FF A0 00 - 00 00 00 00 00 00 00 00 ................
3:23:30 PM #26 Text 0 File Cdrdrv.cpp, Line 1276
15:23:30.593 - _NEC DVD_RW ND-2500A\H1 T1 : Queue again later
3:32:58 PM #27 SCSI -1135 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x04140000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x16 0xD7 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
3:32:58 PM #28 CDR -1135 File Writer.cpp, Line 301
Write error
3:32:58 PM #29 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
3:32:58 PM #30 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
3:32:58 PM #31 Text 0 File DVDR.cpp, Line 1578
EndDAO: Last written address was 1496927
3:32:58 PM #32 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
3:32:58 PM #33 Text 0 File dlgbrnst.cpp, Line 1658
3:32:59 PM #34 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/17/2001 3:07:32 PM
File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.34, size=23420 bytes, created 12/17/2002 2:20:01 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/16/2002 8:05:10 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 5/10/2004 3:05:02 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1133 (xpsp2.020921-0842), size=87040 bytes, created 10/16/2002 6:31:10 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 1 of 1
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 01:16 -
Sudden RipBot error (avisynth error)
By Charles314 in forum DVD RippingReplies: 5Last Post: 24th Oct 2010, 01:44 -
Write Error with Internal DVD Writer
By Soviani in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Oct 2009, 00:50 -
Write error problem with mpeg streamclip
By mattcourage in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Nov 2008, 10:57 -
Pioneer 420H - Can't Write Data Error
By cie3 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 23rd May 2007, 22:51
