Well i got this xvid from a buddy of mine and when i try to convert it to a .mpeg using tmpgenc the video screen just stays blank while the audio keeps on converting. Now i tryed opening it in avicodec and it says the video is supported and i can watch it with minimal problems using media player so my question is what do i need to get/do to get the video stream to work? any info would be great ppl THANKS!
Sounds like you need to increase the priority of the Direct Show Multimedia file reader. check this out: https://www.videohelp.com/tmpgenc
Problems with Xvid audio stream
By mijman in forum Authoring (DVD)Replies: 3Last Post: 15th Apr 2008, 22:59 -
XViD 2nd pass problems
By shorto in forum Video ConversionReplies: 2Last Post: 22nd Dec 2007, 17:31 -
Problems with XViD
By trolldown in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2007, 16:32 -
Xvid playback problems
By drwho in forum Software PlayingReplies: 7Last Post: 13th May 2007, 21:14 -
3ivX to XviD problems...
By GangstaRap in forum Video ConversionReplies: 8Last Post: 6th May 2007, 11:25
