The other day I posted a message about my first DVD Copy.
Here's what I did and what happened:
1) I bought a BenQ DW822A Dual Layer DVD Burner
2) I bought a 25-pack of Pine DVD-R's
3) After installing the drive, I updated the firmware and downloaded DVD Decrypter.
4) I ripped a single layered DVD movie to my hard drive using DVD Decrypter(just the ISO)
5) Still using DVD Decrypter, I then burned the ISO file to one of the blank Pine DVD-R's
That was it, then I tested it in 4 different players:
1) Apex HT-100W = Freezes up every 10 seconds or so and keeps doing this...basically unwatchable.
2) Sungale GD1000 = Works perfectly!
3) Zenith DVD2381 = Doesn't play at all...just ejects after 20 seconds.
4) Sony (forget model) = Works perfectly!
The one that I really want to work is the Apex one because that is my main home DVD player...it has built in surround and amplifier etc.
My friend says I should try a DVD+R instead, but I'm not sure if that will work.
The DVD Players page says that the Apex DOES play DVD-R, and it also says that the Zenith one plays DVD-R's!??
I don't want to keep burning usless DVD-Rs...
Should I try a different burning software or maybe a different burning speed or what? I really don't know what to do now...I really just want my Apex to work with these...but it seems like there's nothing I can do...
Any suggestions?
THANKS AGAIN!![]()
I would suggest buying a good brand of media. I use both Riteks and Prodiscs. You can get them from Rima.com or Supermediastore.com.
Do a search in the DVD Media to review the Pine DVD-R's.
Hope this helps.
I would also suggest a better media.... you can trust media from Apple, Fuji, Sony and Maxell.
Now a lot of other Mfg sometimes use a good OEM Mfg and sometimes not. For instance - TDK uses CMC sometimes (crap) and sometimes they a top of the line mfg. But... you'll never know until you check MFG ID. Download DVDIdentifier ... it will tell you mfg of DVD. Then go to http://www.nomorecoasters.com to determine worth of ID's
Good luck... btw, I've never heard of Pine DVD's -
Just an update...
I purchased a Verbatim DVD+R yesterday and did the same thing with it that I had done with the Pine DVD-R, and I'm happy to say that the Verbatim DVD+R works perfectly in my Apex home theater DVD player.
Now, since Vertabim blanks are quite expensive compared to others, I'm thinking of trying another cheaper DVD+R to help determine whether the reason it now works is because of the BRAND or because it's a +R instead of -R?
What's usually the case? Is it the BRAND of media or the type, + or - R?
THANKS...again! -
Originally Posted by gmrulz4u
Did you buy your Pine disks at Futureshop? They have Maxell DVD's on for 25 for $29 Can., they're very good."Art is making something out of nothing and selling it." - Frank Zappa -
(as DVD_Ripper suggested)
Something else to pass along...
I just downloaded DVDInfo Pro in order to scan my burnt media for errors.
Well, I first tested one of my PINE DVD-R's that I had burnt and it was coming back with a whole slew of errors...ones that DVDInfo displays as:
1. Error - LBA = 0000246ah
2. Error - LBA = 0000260fh
3. Error - LBA = 00002620h
4. Error - LBA = 00002621h
5. Error - LBA = 00002622h
6. Error - LBA = 00002623h
7. Error - LBA = 00002624h
8. Error - LBA = 00002625h
So then I tried to see if my, what I thought was fine, Verbatim DVD+R had any similar errors and it did too!! It came back with at least a couple hundred errors listed just like the above ones!
So what's going on here?? They seem to play fine in various DVD players??
The Verbatim DVD+R is one of the better(older) Mitsubishi Chemical(MCC) types, so I thought that it would be a lot better and have no errors...
Are these Errors that DVDInfo displays just normal or something??
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
