i have this tv episode(mpeg) and i want to cut out all the commercial. what is the easiest way to do this? thanks.
Results 1 to 11 of 11
Computer Spec:
winxp pro, 2.4ghz, 768mb ram, 100gb -
MPEG2Schnitt or Cuttermaran (both are free)
TMPGEnc DVD Author (trialware 30 days unrestricted) -
I've got Womble MPEG Video Wizard and it's great. Womble is probably the best inexpensive MPEG editor. Might be overkill for just cutting out commercials, though. That's why I posted the free stuff, too.
what is the differences between Mpeg-vcr and MPEG Video Wizard
Computer Spec:
MPEG Video Wizard has a much nicer GUI than MPEG-VCR and can do more things. It is set up something like a typical editing program. Re-sizeable input and output windows, drag and drop file loading, intuitive user-friendly controls, text, transitions, filtering, etc.
Both Womble products work very well as frame-accurate editors, are lightning fast and do not re-encode your new .mpg (except right at the edit point or if you use filtering, transitions, etc.). No loss of quality. When you buy MVW, you get MPEG-VCR as a bonus. -
I disagree on the Video Wizard being better than MPEG-VCR because the "cut-between" button is gone. It is harder to cut out sections in the middle of the footage.
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 13:04 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:50 -
best, easiest way to cut bad section out of vob file
By dblake2 in forum EditingReplies: 2Last Post: 16th May 2008, 18:53 -
what is the easiest software to cut an audio file?
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 14:45 -
importing commercial DVD's to final cut
By aquafinity in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2007, 17:31
