i have made 3 different discs that wont play in my ps2.
1.authored and bunred with winavi
2. authored w/ win avi burned with nero
3.authored and burned with tmpgenc dvd author
not sure what ver but i bought it early 2001 and ive played a dvd-r and it played fine, but i cant seem to get one to work. the dvds ive burned work in regular dvd players. can anyone help me with this? also would they possibly work if i checked the force video compliance for xbox thing, or is that just for xbox?
Are you using DVD+R, DVD-R, DVD-RW, or DVD+RW media?
My PS2 will not play DVD+R, DVD-RW, nor DVD+RW media. But will play DVD-R and DVD+R with DVD-ROM booktype.
Can't say if Nero works for PS2 or not, I use either Primo DVD, or DVD Decrypter to burn my images. I have used TMPG to author and burn, which worked fine on my PS2s. -
That's a puzzle.
I also do have problems with projects that use MPEG1 video, but use MPEG2 Menus.
Older PS2s, the first 2 versions, are very picky about which media you use, the newer PS2s have better lasers, and better compatibility. My PS2 does play Maxell and Taiyo Yuden media fine, but has problems with some other brands.
I'd try better/different media, or, since you say they work on other dvd players, don't worry about it
i only want them to play in the ps2 so i can watch them in my room. how much do apple dvd-r's cost. cos i know the one dvd-r i played was burnt on an apple.
Playback problems
By erica12 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2012, 20:33 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
Playback problems in Premiere
By JustinBaker in forum EditingReplies: 4Last Post: 7th Nov 2007, 11:41 -
Playback problems
By Dick Stilton in forum Newbie / General discussionsReplies: 4Last Post: 26th Aug 2007, 08:21 -
Xvid playback problems
By drwho in forum Software PlayingReplies: 7Last Post: 13th May 2007, 22:14
