I have been looking in to water cooling lately, it seems like a pretty good idea. For those of you that have experience with water cooling would you rather go with a water cooled case or just by a system by itself, and are there any major benefits to water cooling besides running pretty much silent? Thanks again guys.![]()
A work associate added one to his AMD cause it was crusing at the 80+ degree mark all the time. By adding the water cooling it only netted him about 5 degrees. He was happy .
If he was at 80+ degrees-C then there is something wrong w/ his setup. mine never passes 54c and I just have 3 case fans.Originally Posted by DVD_Ripper
That's what I thought... but it is in a room that is not air conditioned, 4th floor... Also, all CPU's (including intel) run at different temps depending on modelOriginally Posted by Treebeard
4th flr non air conditioned would explain a lot. I am running an AMD also.Originally Posted by DVD_Ripper
if I was him I'd pop off the side of my case and put a box fan there. -
I would rather save the cash and put it toward a phase-change cooling system. I'd have one already but the ones for dual-proc systems aren't OEM kits, you have to customize them to work. For single processors they would rock.
Are water-shield discs necessary?
By SilverBlade in forum MediaReplies: 24Last Post: 24th Feb 2009, 22:40 -
Awesome Water Show
By joytimeday in forum Off topicReplies: 3Last Post: 28th Dec 2008, 15:14 -
Water for Gas?
By MeDiCo_BrUjO in forum Off topicReplies: 2Last Post: 17th Jul 2008, 17:10 -
water cooling systems
By romanstopme in forum ComputerReplies: 18Last Post: 29th May 2008, 11:12
