Hi,
All
I have a slight problem with this software.
Basically when i try to load my mpeg file in and convert to dvd
it says i do not have enough space on my hard drive?
The conversion says it needs 8gig but i have at least 15gig on my
hard drive? Why does it need 8 gig when the file is only going to be
4.7g
Any ideas?
Also will source creator combine to seperate mpeg's together seamless?
RS
Don't know if this has anyhting to do with it but my hdrive is set
to fat 32. Been told i should re format to ntfs or something.
RS
SubX, a new free open source subtitle creator
By elfdata in forum SubtitleReplies: 8Last Post: 29th Jun 2012, 15:28 -
Problem with subtitle creator 2.2
By ashkan_vpm2 in forum SubtitleReplies: 0Last Post: 1st May 2010, 18:43 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 11:43 -
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11
