Hi have a Episode DVD, where the Menu is screwed up. The dvd has 3 episodes. The link to the first epside is fine. The link to the second episode, plays the third episode, and the link to the third episode plays nothing. So i cant get to the second episode.
Im pretty sure menuedit fix's this, but im not sure how to go about it. Ive tried to refer to the guides, but cant find a guide for my problem. Can anyone help, with a few steps.
If the buttons jump directly to the episodes, it would be easy to fix. If they link somewhere else, you'll need to check where and what's happening there. What are the button commands? Click on the button and click on edit - it will tell you the command.
Removing/Hiding Buttons - Menuedit
By _impromptu_ in forum Authoring (DVD)Replies: 6Last Post: 8th Nov 2007, 20:33
