Hello,
I am about to buy a Philips 642 and have some stuff that was captured from HDTV and converted to XviD at 960X528. I would like to convert it down to play properly on this new player, 640X352 widescreen at a lower bitrate while loosing as little quality as possible.
I don't know that much about XviD but I do know that this sort or transcoding can be done. Also, I have heard that the Philips machine doesn't like stuff converted with Q-pel so is there a tool to look at the file to see if it was converted that way and is there a way when converting it to remove this?
Lastly, since I am just getting into Xvid coding what is everyones favorite XviD guide or tutorial? I am familiar with Tmpgenc. Is there any way to use it's gui for the Xvid codec? not going from Xvid to MPEG but just to convert with the Xvid codec.
Thanks a bunch,
Mike
Anybody? Surely some one can at least give me a clue about some of this?
I can't help with the Xvid or HDTV side of things, but you can definitely use the TMPGEnc Gui.
All you need to do is select Files/Output to File/AVI File from the main menu. you can then select cdec and compression options.
I'm not sure this would give you anything over and above using virtualdub (using the resize filter and recompressing the video). Maybe give both method's a try on a small sample of your source video and see if your player likes it.
You may also like to have a look at the forums on doom9.net where there is a load of f information and some "one click" tools as well.
Good Luck.
Apple Pro Res HQ .mov convert to Huffyuv .AVI
By christianolovesvideo in forum Video ConversionReplies: 8Last Post: 6th May 2009, 14:30 -
Samsung HT-Z310 and Hi Res Xvid / Divx
By TooterDon in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2008, 18:17 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 00:35 -
Convert Xvid versions to Xvid 1.1.2
By mdavenport in forum Video ConversionReplies: 23Last Post: 11th May 2008, 19:01 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 11:55
