I tried few plugins (BorderControl, FillMargins...) that are compiled for AviSnyth2.5 (as it is stated on their sites and also they are listed in AviSynth page as 2.5 plugins) but when I try to load them in script in AviSynth 2.5, I keep getting error:
xxx is not AviSynth 1.0 plugin
Run a Version script to ensure that even though you have 2.5 loaded on your system, you actually are running it.
Hello. -
I just solved problem!
The thing was in VirtualDub where I get that message after loading AVS script - because VirtualDub used old v1.0 AviSynth DLL...
With VirtualDubMod works fine... -
I search for an AviSynth DLLs and found one from version 1.0 in VirtualDub directory... that make me suspicious
I actually didn't try script in anything else because I usually preview settings in VirtualDub...
Can't open FLV with Avisynth
By Greensmurfet in forum Video ConversionReplies: 1Last Post: 21st Oct 2011, 18:00 -
Is there a way to use avisynth plugins/filters within Virtualdub?
By Milardo in forum EditingReplies: 5Last Post: 5th Jan 2011, 03:52 -
AviSynth open failure:
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 29th Jul 2008, 20:35 -
Basic question about AVISynth plugins
By sd_smoker in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2008, 11:04 -
How to install plugins for Avisynth?
By 1gnition in forum Capturing and VCRReplies: 4Last Post: 19th May 2007, 19:06
