Hi All,
I have been "capturing" my 20 megatons of VHS tapes as DV using a camcorder with AV->DV conversion built-in. So far, the majority of my caps have been about 2 hours in length. I am using a Canon ZR60 camcorder, Ulead Video Studio 7, and have been capturing my files as Type-2 DV. Up until now, through many captures, things have been great...almost no problems.
Trouble began last night when capturing the entire length of an 8 hour tape. Basically, the video ends up being fine - but the audio cuts out completely after roughly 2 hours or so and does not come back. I've made 2 re-tries, both while watching the capture as it occurs (to make sure audio is playing), and both have yielded the same result. On my last attempt, audio dropped off at approx. 90 minutes, and I know for sure that I've done captures that have lasted longer than that, so I'm a bit baffled here.
Scoured this forum, google, and the newsgroups...all to no avail. Has anyone had any similar experieces with this? Ulead is current, by the way - all updated, patched and snazzy-like and I'm using about the best hardware out there. After 24 wasted hours (plus fiddling time) of trying to get 8 lousy hours of crap on to this system, I've about had it. If anyone could shed some light on this, I'd very much appreciate it.
Thanks...
Zeeker
Hmmm. Unfortunately, out of frustration, I've already nixed the captured file and so I guess I'll have to try again to check out Gold Wave.
On the CPU question, thanks for the thought. But with a camcorder that's doing almost all the work for me, do you really think CPU load would be an issue? I'm also running (2) 2.8 Xeons on this monster over here, and task man tells me I'm not pushing the envelope - so it's all still a mystery.
Any other ideas?
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
PSP encoding woes - chipmunks overruning the audio
By Cyntalan in forum Video ConversionReplies: 0Last Post: 27th Jan 2011, 20:48 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
good pvr wit this
By monks19 in forum Capturing and VCRReplies: 6Last Post: 17th Apr 2010, 01:23 -
RMVB conversion end up without audio
By alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 00:34
