Latly i've been getting alot of blue screens of death saying windows temporarly cannot read from hard drive.
I'd like a good program to check my disk to see if it's going to die because this unit is still under warrenty until october but i need to back up my outlook files
If it is a Maxtor download their PowerMax Diags... both basic and indepth diagnostics.
Ideally check with the manufacturer of the drive.... most off the shelf products will do surface scans but you need to look at the drive components and the mfg diags will do that better than anything else. -
Yeah get it from the manf of your HD, or download.com
Make sure you HD cable is working right & plugged in securely.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 18:05 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 17:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38 -
how to check which udma mode is supported by drive?
By cL0N31 in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Oct 2007, 23:19
