Hi,
Can someone tell me the best way to put VCDs onto a DVD without re-encoding them. I just want to store multiple VCDs on 1 DVD. Do you just rip the DAT files from the VCDs? and rip it as a Data disc?
Rav.
Click on the green "all guides" over there <-<-<-, select "format conversion" then select "vcd to dvd'. Or just click here.
"Art is making something out of nothing and selling it." - Frank Zappa -
Tmpgenc DVD Author is a nice little tool that will take your VCD MPGs, and will automatically recode the audio to 48khz for you, allowing you to import your VCDs directly to DVD...
I ended up using TMPGEnc DVD Author. Made some nice menus although I kept the chapters as is. One little prob. I had was trying to put NTSC and Pal vcds together. TMPGEnc DVD Author is for dummies, so it does the work for you.
I believe if you click "add new track" you can mix video types.Originally Posted by Raves"Art is making something out of nothing and selling it." - Frank Zappa
Originally Posted by ZippyP.
Yeah I did have them on seperate tracks for each VCD source. I just ended up making another DVD. Only used 2 gig on each DVD, but it was for a trade so I didn't bother adding more stuff.
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
Converting, storing...
By RDS1955 in forum Video ConversionReplies: 4Last Post: 22nd May 2010, 20:03 -
How to burn multiple VIDEO_TS folders to one DVDR w/Menus/Chapters
By Iceman67 in forum MacReplies: 11Last Post: 23rd Jan 2010, 18:10 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 16:45 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52
