Hi all, I'm new, and hope this question is in the right spot.
I've got a DVD .img file, and am not sure how to burn it to DVD. I'm using TMPGEnc DVD Author, but can't seem to make this file work with it. Any suggestions on technique or software I should get?
Mahalo!
burn it to a dvd with nero or prassi or recordnowmax or mount it with DAEMON tools
Thanks for the suggestions. I tried using Nero, but it doesn't like my .img file.
nero will burn img file .....
file -> burn image -> slect all files from drop down -> pick image file -> pick block size (ussually default)
burn
i think DVD Decrypter will also burn image files (not sure)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Rename it to .iso and burn with Nero (Burn image to Disk fonction) , works every time
How to obtain a tiny sample of an *.img file from a huge *.img file
By lousk in forum Newbie / General discussionsReplies: 3Last Post: 16th Nov 2010, 08:03 -
Feedback: vbulletin, [img][/img] tags not working.
By vhelp in forum FeedbackReplies: 5Last Post: 27th Jan 2010, 23:51 -
Problem with .IMG/.ISO file
By macamba in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 03:57 -
error creating an img file
By theft in forum ffmpegX general discussionReplies: 8Last Post: 2nd Nov 2007, 15:05 -
IMG file, no sound??
By newtonnjd in forum Newbie / General discussionsReplies: 7Last Post: 14th Jun 2007, 18:56
