I use my old Panasonic WJ-AVE5 video proccessor (remember when video editing was done with tapes!) it makes every video tape i've put on my DVD recorder rock solid and stable. You will probably pick one up cheap on ebay.
Results 31 to 39 of 39
I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
Rufus T. Firefly (Groucho Marx) -
That JVC 9600 VCR probably has an excellent comb filter, along with the built-in line TBC, DNR and image enhancement circuits. So, use your eyes and best judgement - do a couple of test captures using both composite and S-Video to see how it looks.Originally Posted by K4S3RYN
I did not get a AVT-8710... I picked up a pro broadcast type TBC made by FOR-A for cheap. It produces a very stable, noise free image and has some nice video processing controls, but it softens the picture a bit too much for my taste. -
Yes, those are supposed to be decent... I think they have a TBC built in them, too?Originally Posted by wonderuss
Right you are.. but your tip is well heeded for hooking up other things.. and should i get the box of tricks and need to hook it comp in svid out. There was quite a bit of noise even still on my old LD player.. so now i know what to try.. cheers again
You listed the PV-CC50-K with all of the TBCs. Does this unit serve as a TBC also?Originally Posted by zorankarapancev
BJ -
The Panasonic PV-CC50-K is only color corrector and simple titler.You listed the PV-CC50-K with all of the TBCs. Does this unit serve as a TBC also?
For those curious, I bought the AVT-8710. I will do some tests in the following days and report my results. Hopefully wifey will give me some time...
Darryl
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
DVD Recorders with TBC (by Brand?)
By tambrent in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th May 2008, 19:46 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58 -
Which Pioneer recorders have a working TBC?
By djnice in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th Jul 2007, 05:26
