I need to make a 30 second loop from a wave file, what the easiest program for this?
what are you using the loop for - where is it going to be played?
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
okay, so you just need to cut a wave to loop evenly, Flash should be able to loop it for you on playback.
I use Wavelab, but you could use SoundForge, Audacity, any audio editor. most will have a loop-playback function, where it will loop a highlighted region.
highlight the section of the wav that you think will make a good loop, and start the loop playback. if you hear hitches in the transition, move the edges of the highlighted region until it sounds smooth.- housepig
Housepig Records
out now:
Video Loops Background
By wwaag in forum EditingReplies: 4Last Post: 23rd Sep 2010, 20:22 -
What's the best-easily working program to rip sound from vcd ?
By billyww in forum AudioReplies: 1Last Post: 20th Jan 2009, 06:30 -
best sound program to work with Vegas?
By templedog in forum AudioReplies: 4Last Post: 1st Dec 2008, 13:26 -
AKAI LCT2721AD Cant program the remote and very poor sound levels.
By ibex333 in forum DVB / IPTVReplies: 2Last Post: 14th Apr 2008, 11:01 -
authoring program with dts sound
By tommcd64 in forum Authoring (DVD)Replies: 3Last Post: 25th Feb 2008, 12:59
